Spout connector help
Old 04-24-2010, 09:14 PM
g3mustang
g3mustang's Avatar
Default Spout connector help
Tried set timeing tonight car drives fine... Set it at 14* with the spout out but when I hook up the spout connector the timeing didnt change and I thought it did... why??? Again I'm driving the car and it seems normal but I'm lost please help
g3mustang is offline
Old 04-24-2010, 10:01 PM
AdderMk2
Banned
AdderMk2's Avatar
put a paper clip into each side of the plug (not the gray connector, but the part with the wires) and recheck your timing
AdderMk2 is offline
Old 04-24-2010, 10:04 PM
Bubba 95SN
Bubba 95SN's Avatar
Adder is tring to see if your spout connector has continuity.
Bubba 95SN is offline
Old 04-24-2010, 10:21 PM
g3mustang
g3mustang's Avatar
If I don't have a paperclip can I use a jumper wire??? Also I lied when I put the spout in the timeing retards by a couple degrees and ideas why???
Old 04-24-2010, 10:56 PM
g3mustang
g3mustang's Avatar
Ok I fixed it the connnection was dirty cleaned it know all is good the I think... Set at 14*. Then with the spout connected it's around 23*
Old 04-25-2010, 01:05 AM
nitrous_bob
nitrous_bob's Avatar
probably...
but you need to set it w/ the spout out fo sho
with the spout it , it won't jump around, set it right on 14* and then plug the spout back in
doesn't much matter what it jumps all over to after that, it kinda sets itself
nitrous_bob is offline
Old 04-25-2010, 12:16 PM
g3mustang
g3mustang's Avatar
Thanks for all the help
jwog666
12-27-2021 08:09 PM
Seanam
10-04-2015 10:15 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
TfcCDR
09-14-2015 12:08 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Spout connector help
