if it is currently running rough, grap a set of insulated pliers and pull wires one by one replacing them back on the cap until you pull one where no load change is noticed, then at that point you'll have the cylinder that is misfiring and we can focus diagnosis on that cylinder
well......Huston we have a problem! I have a bad TC, I was doing the cylinder test after the code diagnostic test and as soon as it rev'd up to about 4000 rpm, bam blew it out. I am going to replace and check everything and as osoon as that is completed I will resume my previous problem, thanks for your help!
well, I did a cylinder balance test. I found #3 bad. i checked all wires and connections, all good. I found the injector bad, replaced and running perfect!!!
