Need help!!
05-03-2010, 09:02 AM
Need help!!
i just bought a 5.0 and it needed head gaskets so i replaced them and i got it all back together but whenever i went to adjust the rocker arms there is play in the push rod the rocker arms are none adjusting. it has a bolt that runs straight through into the head so i need some advice what do i do...
05-03-2010, 10:20 AM
Lifters have bled down.Will pump up when gets running.
05-03-2010, 12:21 PM
that wont bend any of my push rods??
05-03-2010, 12:47 PM
as long as they're not falling out of the rockers, you should be fine to start it up and pump them up. if you're really concerned you could buy a oil primer and pump them up manually.
