need some help with gt40p heads
Hi all,
Need some help, I installed gt 40p heads on my stock 1988 5.0 HO and when i tighten down my rocker i have alot of lash left, do i need to get longer push rods? or is there something else i need to do?
Would anyone know the length of the push rod if that is the problem?
Thanks in advance for any help
Mike
p.s. i also installed new lifters if this helps anyone to help me
Mike
if you are using stock pedastal rockers and stock push rods and a stock cam, the stock length are fine, the lifter plunger collapse when no hydraulic pressure is present which is why yuo have lash, no worry, however if you have a non stock cam and are using roller rockers, you need to measure for length, no ifs ands or buts...
this is my first head install, I`m using stock pedastal rockers and stock push rods and a stock cam. So if i get everything back together and adjust then,everything should work?
Thanks alot for your help. Thought my pony broke a leg and was going to have to shot it.
Thanks again for your help
Mike
Mike
ok got heads on and car running....now the engine keeps reving up and down from about 1000 rpm to 2000 rpm... i can make it stop by turning down the timing but then the timing is to low and just pops... if anyone has any ideas i sure would be grateful
Thanks in advance
Mike
Thanks in advance
Mike
