Weird Nose from Power Steering Steering Pump
So today I noticed a weird noise from my power steering pump. It seemed much louder than normal. When I popped the hood there was some power steering fluid leaking. Would this imply a bad power steering pump or a hose leak & just low fluid?
Thanks,
Jason
Thanks,
Jason
Power steering units make noise when air enters the system and/or are low on fluid. Fixing the leak, retopping the fluid, and "burping" the system will likely fix most of the noise, but old Fords are notorious for a little whine, and you'll likely have to replace your entire hydraulic steering system and use synthetic fluids to complete eliminate any noise.
If you do need to swap out the pump, I just had good luck with a Pep Boys reman for about $50. Very little noise after the swap. That sounds a lot like what mine did. Made some noise with a small leak, then one day it was screaming and gushing.
uberstang1
09-20-2015 06:42 PM
09-08-2015 11:50 AM
