Motor hesitates in 4th??
Old 05-13-2010, 05:50 PM
Force4
Force4's Avatar
Default Motor hesitates in 4th??
I dont have a 5.0 but this could be related to anything so I figure I will also post this here.
In 4th gear at about 4300-4500 RPM's my motor starts to randomly hesitate (feels quite jerky) but then it starts to smooth back out around 5000rpm. I am loosing my trap speed because of this and I dont know what would cause it. I am using a 750cfm 4 barrel carb. (summit street/strip) which is only a year old. My timing is not advance nor retarded(10 degrees). It only does it in 4th which is why I cant figure this out... first-third it just rips right to 6k. Any suggestions?
Force4 is offline
Old 05-15-2010, 12:26 PM
Force4
Force4's Avatar
Update: Went to the track tonight, out of 3 runs the motor was hesitating in 3rd now also at around 4000-4500. Then I got on the freeway home and got on it a bit and it didnt start till 4th again. Sounds like a lack of fuel to me eh? Timing is exactly at 10 degrees so I do not think its the problem.
Force4 is offline
Old 05-15-2010, 12:58 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
lot a load in 4th, defiantly look at fuel
TrimDrip is offline
Old 05-15-2010, 04:17 PM
67mustang302
67mustang302's Avatar
What do the plugs look like? Could be too lean, could be too rich. Does it get a surging hesitation? If it does then it's lean. If it has a blubbering type of hesitation, or seems to hiccup and stutter without surging or popping then it may be rich.
Has this problem suddenly started? If it's been fine but now this problem is occurring, then something has failed...fuel pressure problem, regulator, torn diaphragm etc.
Is the carb vacuum secondary? Post pics of the plugs.
67mustang302 is offline
Old 05-16-2010, 12:31 PM
Force4
Force4's Avatar
Its running a vacuum secondary. Its consistency is leaning heavily towards a lack of fuel. Literally at like 5 grand in 3rd the motor just stops and starts to pop its way up slowly. If i get on it from a roll, the problem wont start until 4th. I am going to start basic and replace my fuel filter and put on a high volume fuel pump.
Force4 is offline
Old 05-16-2010, 10:11 PM
67mustang302
Check to see if the rubber diaphragm for the secondary activation is torn.
Old 05-17-2010, 04:20 PM
Force4
Force4's Avatar
Good idea I'll check that also thanks
Force4 is offline
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
RCS02v6
09-29-2015 01:46 PM
logan409
09-26-2015 07:43 PM
Quick Reply: Motor hesitates in 4th??
