Clutch Pack Assembly 8.8
Hi all,
My hands are covered in smelly friction adative so ill make this quick.
First of all. My ford replacement clutch kit came with 8 clutches.
Yes, all 8 are actual clutches, 2 are not spacers.
Ok, when i disassembled my carrier a week ago it went like this:
Gear teeth, clutch, shim, shim, clutch, shim, shim, clutch.
From what i was going by, this diff has never been apart.
Is that order above correct? Why do i have 8 clutches? I only use 6?
A diagram of a ford 8.8" exploded carrier would be superb!
Thanks guys!
Thanks guys!
Im not to worried about it. I did it the way i mentioned before.
Good times. Just dealing with pinion shim now.
It was a btch trying to get the S spring in. That clutch its packed extremely tight!!!
It was the spring that i pulled out of there too!
Check this website out. it should have everything for a rebuild http://www.angelfire.com/theforce/5o...5ohtech001.htm
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
