Charging Issues
Charging Issues
As most of you know I got the 93 running and I am having charging issues. I took the alternator to advance today and it tested out fine. So now I have to figure out what is up. What else is there that would keep it from charging? I did a continuity check on the power wire from the alt to check for the fusible link and it beeps. As I am looking at the schematics I haven't checked wire 36, yellow/white 14 GA that runs from the regulator to the main wire. I would guess that is what gives the excitation voltage for that extra 2-3 volts? Either that or the white stator wire doesn't have a good connection but when I taped it all up it looked pretty good. I had to cut it and resolder it because it had a nice cut in it. Any ideas???
