Help with motor mount and trans mount
I am in the process of buttoning up my motor build and was wondering if anyone knew the motor mount to block bolt size and the size of the nut for mounting the motor mount to the car?
Also, What size bolts do I use to mount the trans to the crossmember? The roller didnt come with any of those bolts so I am at a stand still until I get the correct sizes. Thanks for all the help.
I can't tell you exactly but I know they are regular SAE bolts. When I don't have a bolt I find one around the garage and see if it works and then go get one from the hardware store. You could also go to a junk yard and pull some. The easiest thing you could do is go to the hardware store and grab once of a few sizes and see what works.
logan409
09-26-2015 07:43 PM
mrappe
09-26-2015 10:16 AM
LivingInThePast
09-16-2015 12:20 PM
