K-Member, Motor Mounts Questions
I just purchased an '81 hatchback today and it has a 3.3L inline 6. It goes without saying it will be replaced with a 302. Eventually I plan on acquiring a tubular k-member, but for now I will run the stock k-member. Will a 302 bolt in placed using 302 motor mounts to this k-member?
Fred
Fred
Google provided a link where it was said that the 3.3 k-member was the only oddball out of the whole bunch. Actual motor mounting position is way forward compared to the 2.3 and 5.0. Can anyone confirm this? Just my luck.
yea everything else should work but like mentioned your 6cyl k will not work. if possible i would try and upgrade to the later fox brakes at this time as i believe the early 81's had the small brakes like the later 4cyl cars
I actually already have 94/95 spindles on the way as well as new hubs, rotors, and calipers. The rear will get the 94-98 10.6" disc brakes using the North Racecars brackets. I picked up an 8.8 last night and will be hunting down Ranger axles to convert to 5 lug. Thanks for all the help fellas.
Luke9222
10-22-2015 11:55 PM
