3pod Cowl gauge info
Alright,
So i have been discussing a clean way to install 3 gauges oil pressure,fuel pressure and boost using a CowlGaugeConcepts gauge cowl vent grille so they call it, I am using braided lines for everything and i want to still be able to use the wipers, if needed. The oil pressure is running off the location of the stock sending unit, and the fuel pressure off the shrader valve, and the boost line is getting T'ed into the line going to the BTM BOX(if this isnt the correct plave to T in please feel free to point of the correct location) On the website they have everything running across the motor to the driver side and then drilling a hole there to feed the lines through, I wanted to see how everyone else has done it where they tapped there line through, obviously pictures would be practical but any help is appreciated. Thank you to mjr46 who has already been helping me with a clean setup and to all those that will post up to these.
Thank You
Bryan
PS
This is the exact Gauge pod i am using
http://www.latemodelrestoration.com/item/CGC-02228B
Thank You
Bryan
PS
jwog666
12-27-2021 08:09 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
junior04
09-28-2015 10:53 AM
