build up!!!!!!
build up!!!!!!
ok....... i just got a bunch of money and im puttin 3 grand into my stang for now and i was wonderin if i could get my car into the 12's with this much ...... i want to do upper and lower control arms springs and subframes for the suspension.... i want it to be all motor no nitrous or forced induction....... i also want to beef my tranny up alittle ...... what all should i do?
RE: build up!!!!!!
what is a good head and intake and cam combo?
i will do all of that you listed too stangpower ....will this improve my handling alot or just help me hook up better?
RE: build up!!!!!!
The SF's and U/L's will do both,improve handling and traction,and you will get alot of differnt respones on the best H/C/I combo,but i will throw you my idea and that would be the Trick flow package with twisted wedge heads.
RE: build up!!!!!!
Well roughly around 3g's for H/C/I,roller rockers,valve covers,gaskets,etc.Then you will need 190lph fuel pump,injectors,AFPR and a good clutch.Your tranny will be fine as long as you don't attempt anypower shifts and act like you got some sense.
RE: build up!!!!!!
Oh,well that's a totally different story but i assure you it won't last long behind a H/C/I motor if its stock,Maybe QUIK will drop in and give his advice since he know's his AOD'S.
RE: build up!!!!!!
first whats wrong with nitrous?
also subframes arent suspension its a form of chassis stiffening. this is what i would do if i was you. get some 70/30 struts up front [90/10 if all track] 4cyl springs on the front, stock v8 springs on rear, 50/50 shocks on rear, U/L CAs, keep rear sway bar intact. as for stiffening up i would go with full lenght subframes, get torque boxes reinforced, aluminum DS, 410s, rear end girdle, 3k stall.
for the tranny... get a good shift kit, 3k stall, largest tranny cooler you can get, a deep tranny pan, upgraded servo, poly tranny mount. now if you really wanted a great tranny you would need a solid 1 piece input shaft, kelvar clutches/bands, 2' OD band, A+servo or billet servo, Lentech or Art Carr VB, along with a 3k stall, deep pan and of course a large tranny cooler
personally i wouldnt worry about heads or intake and cam right now. i would go this route then start to look for parts like a 70mm tb, eldy performer,TF SH intake, GT40 intake, GT40E, then look for a set of GTP heads, eldy heads,GT40 swirl heads then a TFS 1 cam, AMS cam or even a crane cams one. something with around 500 lift and around 224 ish duration and 112 lope sep.
reason i said 70 mm tb with this combo is cause of the steep gears and the AOD with the 3k stall. this will be very beneficial. but suspension is KEY
RE: build up!!!!!!
sounds like more money than what i have lol....... what could i run if i knew what i was doin with a setup like this.....i would like to see a low 13 or high 12 in the quarter..... and i said no nitrous cause i just dont want it right now.... ill get it later
