9 inch rear end help
I have a 89' mustang and was needing a 9inch rear end. I found one off craiglist from a older cougar will it fit? or should i just stick with a 8.8?
build the 8.8 save some headaches
why do you feel you NEED a 9" rear end?
didnt mean it as OMG I NEED A 9INCH REAR OR IMA DIE..
But if i can find one.. why not buy it?
Originally Posted by mrkline006
(Post 7070570)
Unless you are making more than maybe 700HP at the crank just use the 8.8.
Much less money to put a spool/axles in it than to mess with the heavyier 9"....... |
