over heating
over heating
I HAVE A 1995 5.0 SUPERCHARGED WITH BRODIX HEADS I AM HAVING AN OVER HEATING PROBLEM DURING ALL SEASONS IVE PULLED THE THEMOSTAT AND DOES NOT HELP THE FAN WORKS ON BOTH HIGH AND LOW SPEEDS NEED HELP.
First off, and not to be a dick, don't use all caps. How's the power with the car (is it normal) you could have a blown head gasket if it feel weak. You also didn't mention if you had upgraded the radiator or not, the stocker could easily be clogged, and so could an aftermarket three core aluminium one. Also I would check and see if my radiator hoses were collapsing on you, silicone ones are a good upgrade. And running without a thermostat can lead to other problems since the car doesn't heat up properly. Also the gauge could be lying to you.
-head gasket blown
-radiator clogged
-possible hose collapsing
-bad sending unit/gauge
-head gasket blown
-radiator clogged
THANKS FOR YOUR REPLY
IVE GOT A BRAND NEW WIRE LOCK HEAD GASKETS AND ARP BOLTS I PULLED THE THERMOSTAT TO TEST THE PROBLEM , I HAVE THREE TEMP GAUGES TWO ANALOG AND ONE DIGITAL, BOILING WATER WOULD BE A GOOD INDICATION OF OVERHEATING. THE RADIATOR IS BRAND NEW SECOND NEW ONE BECAUSE OF OVERHEATING PROBLEM AND SINCE WERE SPELL CHECKING FEEL SHOULD OF BEEN FEELS NOT TO BE A DICK THANKS FOR REPLYING.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
