I just recently put some heavier rims cause they look really awesome on my stang, so the ABS light came on, what can I do to get this corrected, or do I have to take it to a pro? And why you ask I put heavier rims, because they are 20" chrome and sexy, and got for free.
I doubt it is because you have a heavier rim. What size tires are you running now? Usually the thing that effects the ABS is using a taller tire than stock. Stock is only a 26 inch tall tire, if you use a taller one that will cause the abs light to come on.
if you are running a different diameter tire up front vs rear wheels speed in the front will be different vs rear and thus potentially trigger abs light.
