Adjusting Ring & Pinion Backlash
It is an original one with 3.27s so I'm going to measure the pinion depth in that rear end then get mine to match up with that one. Hopefully it works. I still have some axle movement out the passenger side so I figure the pinion depth needs to come towards the ring about .005 so then I can move the backlash over a similar amount more to the driver side.
I actually happen to have a 1997 stock cobra rear end laying around because my brother is putting it in his 70 mach 1. I'm almost done making a pinion depth tool that mounts with the differential cap bolts.
KingRando
10-02-2015 08:06 AM
