BBK CAI install issue
Old 07-28-2010, 09:20 PM
captahab
captahab's Avatar
Default BBK CAI install issue
I just installed a BBK fender CAI kit in my car.
No matter how I shift it around or angle the tubes
I cant seem to get the tube that goes from the MAF
sensor to the throttle body intake to stop rubbing off
the front strut tower.
There seems to be about a 1/8 inch of clearance between
the two and when the car idles it occasionally hits the body.
I do have Cobra uppers and lowers on it, Im not sure if that is
a issue. Im thinking that these are designed for a factory type
replacement.
I could probably cut off a little on the pipe and that may buy
me a little more clearance.
Has anyone else had this issue before ??
captahab is offline
Old 07-28-2010, 10:07 PM
ALMOST STOCK
ALMOST STOCK's Avatar
I've heard for the past 10 years on different forums that you need to cut just a little off the pipe so I'll assume that's what you''ll need to do to make it fit right.
ALMOST STOCK is offline
Old 07-28-2010, 11:52 PM
enix187
enix187's Avatar
cut an 1/8 to a 1/4 off of the end that goes into the throttlebody, make sure you deburr the edges, that'll clearance it out
enix187 is offline
Old 07-29-2010, 07:47 AM
nacanitihs
nacanitihs's Avatar
cut it and then install some poly motor mounts so your engine doesnt move around as much
nacanitihs is offline
Old 07-29-2010, 01:08 PM
Bubba 95SN
Bubba 95SN's Avatar
+1 on poly mounts. Had to trim my BBk cai. Seem aftermarket parts come close, just need adjusting. (metal removal, bending, and why did I pay good money for something that does not work out of the box?)
Bubba 95SN is offline
Old 07-30-2010, 03:04 PM
enfausn
enfausn's Avatar
Mine fits ever so close with a factory intake. I'm going to the cobra intake soon so it's good to know i should just go ahead and cut off a c hair on that pipe. thanks
enfausn is offline
Old 07-30-2010, 07:23 PM
captahab
captahab's Avatar
Thanks for all the replies on this. My motor mounts are pretty shot.
Im sure that caused alot of the problem. I took 1/4 inch off the pipe
with a chop saw and it gave me just enough clearance so it doesnt hit
the strut tower on idle.
My next project is to swap out the motor mounts sometime in the near
future.
captahab is offline
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
Calizic
08-28-2015 01:46 PM
my96mustang
08-24-2015 06:12 AM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: BBK CAI install issue
