Big and Littles on a 5.0 Cobra
I'm sure this has been beaten to death as well but not to many SN95's are runnin skinnies and fatties.
I'm fixin' to mount a set of Pro Stars and I'm not sure of the largest tire size I can run in the rear. I know the foxes can go as high as a 275/50, but I have a little more fenderwell clearance than a fox. Will the 275's fill these wells up or should I go a little higher? Would a 26X10.5X15 be a good size?
I'm planning to run the 3.5" Pro Stars in the front and the 8" out the back
Also, any of you who run skinnies, could you tell me how you like your setup and what your running? Is there anything you would have done different?
11-10-2015 11:39 AM
