one simple way is to take one out that u know works and connect it or see if it clicks when u turn the key on. and what kit u got? i was thinkin of gettin the low boost set up for now haha.
which other relays fit it.
Ya i got the lower boost to see if i liked this brand. i picked up an old paxton unit. its pretty dependable. it runs it at 6 psi. im gonna upgrade when i get the money and i build up
u can use one that looks the same or the same prongs but yeah i might buy the vortech kit from lrs i hope i like it my car is stock except full exhaust and intake and 123,000 did u notice a big gain with the low boost?
idk what lead to you suggesting vapor lock in the fuel lines.. due to the temp of the motor the very first thing I would look at is the ignition module/PIP sensor. They both die from heat.
After you get it fired up, find your coolant leak. start with an oil change.
How do you check the ignition module . what should i be looking for with both of them?
wtf, all these posts and no mention of checking for spark?? check for fuel??? ect ect an old spark plug and a can of ether is all you need to see if it's a fuel or spark issue....
How do i test for spark or fuel???
I replaced the relay and i replaced the ignition control module. and still nothing.
