rear suspension needs fixed!!! pics!!!
so i bought this car cheap and i found out why today, the rear suspension has been jacked up, oh well i guess, ill just have to fix it but i need to know how, i was thinking about making my own brackets and welding everything myself, im a pretty good with a mig and i think ill be able to do all the work myself, or ill have to buy some suspension kit or something, what should i do
drivers side
drivers side
drivers side
passengers side
drivers side
drivers side
drivers side
passengers side
Looks like someone has ripped the brackets apart before. Just use what you have there and reinforce it better than what the previous owner has. Get this and then start some fab work from there. It should take much or be hard at all.
http://www.latemodelrestoration.com/...nforcement-Kit
your brackets are kinda raped huh.. good luck with fixing them
http://www.wildridesracecars.com/sto...cat=249&page=1
This is a good solution for messed up upper mounts.
Good luck!
Good luck!
should be just fine if he is still running a rubber bushing in the axle housing. but from the repair work the previous owner prob had a poly mounts in the housing.. which is a no no. if you plan on going around any corners or over bumps that is..
Good luck!
Good luck!
Black_GT_02
08-20-2015 01:26 PM
