Instrument panel and AC knob light problem!!!!
so i finally got the dash out and I replaced the old heater core with a new one!!!!....I put the dash back but not completeley....I am not getting any air through the vents....I am getting air through the floor vents and also the defroster vents.....but not the ones on the dash!!! any ideas......also I think I found out the problem to the back light issue....since my car is in pieces I am rewiring my stereo meticulously....i found the dimmer wire exposed.....thanks a lot guys......
so I fixed the whole heater core BS....it was an adventure but I did it....no getting back to the other problem....the backlight issue.....I changed the instrument panel again for the second time because the first on I changed was not getting any power....now the fuse is getting power.....but the back lights still don't turn on.....the bulbs look fine....are they any more fuses maybe under the hood? any suggestions or wiring diagrams would be greatly appreciated!!!
I'm a fool....I meant I changed the fuse again for the second time.....now the second fuse is getting power...the tester lights up.....so like I said in the last post....are there any other fuses besides the ones under the drivers side? are there any under the hood? any wiring diagrams would be helpful....HELP!!!! X/
Similar Situation
When you first replaced your new radio head unit, did your turning signal lights and high beam lights light up on the instrument panel when you turned them on? Cause if so, I have the exact same problem. I am in a similar situation.
I have a 95 Mustang 3.8L V6 and when I bought it, it had a custom head unit in it that didn't play CD's so I replaced it and I noticed that the dimmer **** didn't work, and the only lights that work on the instrument panel are the turning signals and high beam. I am also having problems with my AC/heat, the AC doesnt work at all, and the heat only comes out of the defrost...any suggestions...? I really need to get the lights fixed cause I got pulled over last night going 72mph in a 55 zone and didn't even know it b/c I can't see how fast I was going...I can't afford tickets haha.
Does any of the dash light up such as the HVAC controls?
I had somewhat of the same issue as you with no illumination if the cluster or anywhere else. After looking at some wiring diagrams and using a jumper wire, i found out my rheostat switch was bad. replaced that and i had cluster lights
So I fixed my instrument light problem. I decided to take my radio head unit out again and take another look at the wiring. I actually found that for some wierd reason there were TWO grounds one which was grounded out and the other was twisted to the dimmer wire. I unattached the second ground wire and cut it down and the problem is fixed!
