3.73s
3.73s
got my 3.73 gears installed,awsome,....it has more pull,realy fun power shifting now,what I dont like is, first gear is basictly non existant,very quick shift,a little to quick,I dont know if I like that as much as I hoped.Maybe I have to get a little more used to it before I say I dont like it,all in all,I should have done it a long time ago....
RE: 3.73s
I beat it a little today,I guess its not that bad,had to adjust my driving a little,it is worth it once you go through all the gears,for sure...
ORIGINAL: DR8907
I have 3.73s on my car. First is a little short, but its not all that bad. You should get used to it, its worth it for sure once you get into second.
RE: 3.73s
I got 3.55's I think 1st gear is liveable definate butt dyno improvment the downside is top end with the 2.73's top speed was in 4th & if you are running a highyway race you are good but with the 355's you shift to 5th at 125 & 5th is so deep that if you are neck & neck to the shift after the shift its all over
