Explorer INTAKE help
So i wanna get upper and lower intake from an explorer, but what year? i've heard so many different years that i just need it straightened out and should i pull anything else off the explorer while im at the junkyard?
RE: Explorer INTAKE help
96-2001 are the 5.0 exploder years, take the heads too.
the 96 heads are regular gt-40's, the others are the gt-40p heads, which require special headers.
the throttle bodys are 65mm too.
well the 95 to 97 explorers had EGR provision in the intake
98 to 01 explorers have no egr provison in the intake. i
GTP heads can use bbk shorty unequal headers. i knwo cause i have them.
reason you need headers is cause of spark plug clearance. so basically you need MSD mulit angle plug wires. where you can bend them to 90* or so. i did this on my motor
you can get the 65mm tb off them but you need to slightly modify it. but its a cheap 65 mm if you care to do the modding. alot of ppl rather pay for a new one.
95 to 97 1/4 had gt40 headss
971/4 to 01 had the GT40P heads
ORIGINAL: Quik
and what has to be done for a 98 explorer to fit on my stang?
reason I ask because a friend of mine has a 98 upper and lower explorer intake plus the adapter, 65mm tb, and a spacer plate kit for the intake..
well i dont think a 98 explorer will fit in a stang. its just way to large to fit. and besides that truck just is to heavy......lol
the bracket for the linkage is what needs modified, i personally havent done the modding for the 65mmtb but its been done alot.
to large as in.. not lining up with the heads and stuff like that or to large as in not clearing stock hood or anything. I buddy of mine has it and says it will fit... but now that you say it might not, I don't think I can trust him lol.
