93 lx headlight issue
I recently purchased a set of LED projector head lights. The led's look awesome the issue i'm having is that now the dash shows the lights as bright at all times and when i brighten the lights they slowly fade dimmer! but the dash still shows them as being in bright. I'm curious if anyone else has attempted this install and ran into the same issue?
I read somewhere that on projector lights some people were running into the ground and positive wires on the factory harness being reversed and that they need to do the same with the aftermarket adapter, on this i'm not sure how to tell or if there even is a way to tell.
(I can put the factory bulbs back on the harness and the lights brighten and dim as normal)
Nope no instructions as it was suppose to be plug and play i suppose. After tons of google searches and study. I went back to basics and found that the wires on the headlight adapter that comes with the kit were actually reversed (ground wire where the red hot wire should be) after switching them the headlights are up and running and looking good!
