Release Bearing issues!!
Hey guys, I installed a RAM HDX clutch kit in my 88gt a couple weeks ago. I have an adjustable clutch cable and a double hook quadrant. I believe that I adjusted the cable properly to allow the release/engagement point halfway of the total pedal travel. I heard this whining noise on Sunday, went to grease the release bearing on monday after disconnecting the cable completely and found the release bearing in 3 pieces...so, i replaced it with the HD FRPP bearing, but i really don't want to do it again. I need some help on what did or could've gone wrong to destroy the bearing this fast!!
well, i tightened the cable up in about 12 different stages increasing tension each time. i tightened it until i could shift smoothly, and my release point was as soon as i started to lift my foot. so tighten tighten tighten, and now it's about 1/2 way the total distance of pedal travel. sound right?
yeh, mine lasted less than 2 weeks so we'll see how the new one does. the only thing that bothers me is that i have to tighten the crap out of the cable to get the tob in the proper position so i can shift smoothly and allow for proper engagement. i feel like i'm putting too much preload on it. i mean i know the pressure plate "fingers" are stiffer than an oem replacement on, but there is absolutely no slack in my cable whatsoever. even my king cobra had a tiny amount of slop. ideas?
ccdguy
09-19-2015 05:20 PM
09-17-2015 07:57 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
