LEAK
LEAK
I have a 1993 LX and for some reason I have a small leak in my resovior for my antifreeze. My low coolant sign came on and the resovior tank was low which I had just filled up two weeks ago but the radiator is full I know the sensor is in the tank but cant find a leak or wet spot.
Coolant resevoir is just that..a resevoir. Loose coolant and it draws from the resevoir. That being said the coolant loss area needs to be identified. Get a radiator pressure tester. Pump up to 16 pounds. Do this while engine is cold.(makes it easier to get up close look) Have a look, see the problem and then correct the leak.
bradleyb
11-27-2015 07:50 PM
