41 and 91 KOER running lean
Old 09-25-2010, 01:04 PM
Pocn
Pocn's Avatar
Default 41 and 91 KOER running lean
So Ive been told its bad 02 sensors but now I hear there are before and after cat 02s and I dont know which ones I need. Its running lean according to the codes and has very rough cold start up, I have to be on the gas or it will die. It pops and is just pretty rough running untill it gets warm but it goes about half way up the normal temp range which is higher then when I was first driving the car. Ive cleaned the IAC and MAF properly.
Pocn is offline
Old 09-25-2010, 01:19 PM
Bubba 95SN
Bubba 95SN's Avatar
Your car only has O2 sensors one left one right. For a total of 2 not 4.
Bubba 95SN is offline
Old 09-25-2010, 01:34 PM
Pocn
Pocn's Avatar
Okay but are they before or after the cat. The guy at the auto store asked me and I didnt know.
Pocn is offline
Old 09-25-2010, 01:47 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
they are before and the fool at the parts store is just that = clueless, had he a clue he'd know that that car has only 2 and they are before cat as obd 1 does not have catalyst monitors which are done via post cat o2's......and fyi, I would not go throwing parts at it to solve a lean issue on both banks without verifying the prob, it's rare both o2's are bad at the same time, often when I see codes for 02's on both banks indicating a lean condition, I first look for vaccum leaks , tears in the rubber boots before the maf, if your car is SD look for vaccum leaks, fuel pressure issues, o2's are often not in play on cold start since the car runs in open loop operation until ect sees a certain temp then o2's are switched on and at that point control a/f, if your prob is on cold start then I'd look at such things as ect, act, carbon build up in TB or intake.cumbustion chamber track, or Fuel pressure issues, or a vaccum leak, ect ect.............Furthermore, first thing I'd check would be the o2 ground wire at the back of the heads/ intake area = orange wire on an eyelet iirc
mjr46 is offline
Old 09-25-2010, 02:00 PM
Pocn
Pocn's Avatar
Thanks alot for the response... The only codes I have gotten from the car are 21(ECT out of range) 41 and 91 and I was planning to get a new ECT today for sure but looking into how to fix the lean problem before I go buy anything. When it is cold it pops and is sluggish on acceleration and if Im not on the gas the car will die but it runs fine once its warmed up (and it gets a little more up the temp gauge then it used too). Ive cleaned out or replaced the MAF IAC EGR and TB already
Pocn is offline
Old 09-25-2010, 04:14 PM
JodiJay22
JodiJay22's Avatar
i just had the same problem getting codes 41 and 91 making car run lean, it was a loom of wires rubbing against the oil pan near the front of engine, and shorted out two wires., fixed those wires and the problems were gone.
JodiJay22 is offline
Jb145700
08-21-2022 06:37 AM
10-07-2015 07:02 PM
heslekrants
09-23-2015 04:02 PM
SteelerNation82
09-16-2015 07:11 AM
uedlose
09-10-2015 03:30 PM
Quick Reply: 41 and 91 KOER running lean
