This darn AC
Okay, so the belt is turning but the circle that has the triangle like studs wont turn. It is trying to but won't. I tried to take the belt off but it got too dark. Also, when you say don't turn from the front, do you mean the area where the triangle like tri studs are?
And also, do this all with the clutch pushed in?
Bolt in center is on at like 8-12 ft lbs trying to turn will result in broken shaft...compressor ruined. Get clutch energized((so it closes) now try turn the compressor where belt runs. Does not move, compressor is seized..usually lack of oil. Compressor seized will cause belt screech.
mungodrums
09-29-2015 09:18 PM
09-16-2015 03:07 PM
