Help Figuring Out where this vacuum line goes
Old 10-15-2010, 04:25 PM
JodiJay22
JodiJay22's Avatar
Default Help Figuring Out where this vacuum line goes
i just replaced the distributor after having many problems with ignition control module, and also had to replace battery. it seems to be running alot better than before but is still stalling out/loss of power while accelerating. Was taking a look under hood and noticed this vacuum line sitting by the distributor and cant seem to find where it could go. anybody know where this could go?
this line is coming from front of engine compartment near radiator then appears to go across to drivers side of engine compartment
JodiJay22 is offline
Old 10-15-2010, 05:17 PM
marlyman
marlyman's Avatar
prett sure that goes into the middle of the upper intake..behind the distributer not on left side but right side(driverside) u can see the fuel injectors an fuel rails under the upper intake take a flashlight an look in there an there should be a metal tube where u need to connect that vacuum line..hope my description helps..damn sure its that good luck
marlyman is offline
Old 10-15-2010, 06:12 PM
JodiJay22
JodiJay22's Avatar
ok i see what your talking about up there but there is a thicker black rubber hose that is connected there already and runs towards the rear of the engine. i just noticed this though. should this be blocked off? this is under my throttle body. thanks for the input guys
Old 10-15-2010, 06:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the hose you have plugged off, is it going down to a black canister and inline there is a selonoid looking thing??
mjr46 is offline
Old 10-15-2010, 06:33 PM
JodiJay22
JodiJay22's Avatar
yes it does go down to a solenoid looking thing then to a black canister down at the bottom of the frame, but i dont currently have it blocked off i just found it and wanted to find where it goes to?
Old 10-15-2010, 06:53 PM
Bubba 95SN
Bubba 95SN's Avatar
That is throttle cable end or cruise control.
Bubba 95SN is offline
Old 10-15-2010, 07:12 PM
JodiJay22
JodiJay22's Avatar
where does that line go to? could it be effecting my driving i am getting stuttering during accel, and engine jerks vehicle cutting out real bad. but only intermitent
Old 10-15-2010, 07:27 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Thats an evap line. Probably a purge line. that should go into the intake somewhere. where ever it goes is probably a source of a vac leak and that can cause your problems.
Boss_Hotrod is offline
Old 10-15-2010, 07:59 PM
JodiJay22
JodiJay22's Avatar
ok that is what i was figuring but the only place i could see it going would be under the throttle body but it has a plug over it, does anybody know if that is where it goes or where it should go?
Old 10-15-2010, 11:13 PM
mjr46
mjr46's Avatar
as stated that is the evap purge line = goes to vaccum source on intake
mjr46 is offline
Quick Reply: Help Figuring Out where this vacuum line goes
