88gt front end clunk/rattle
i have a 1988 gt the has a clunk or rattle whenever i go over bumps in the road. if i depress the brake pedal before the bump there is no noise. everything in the front end is all stock. i have recently replaced the wheel bearings on both side, outer tie rod ends, sway bar end links, and shocks. does anyone have any thoughts on what this could be? like i said it is only if i am going over bumps without touching the brakes. thank you for any help you can give.
