Where is the headlight relay located
Old 10-20-2010, 03:18 PM
CarolinaRumble
Default Where is the headlight relay located
Where is the headlight relay located? I have been having trouble with my high beams, they stay on for a few minutes, then flash a couple of times then go out. I am able to switch to low beams and they stay on. I thought I should replace the relay and/or the headlight switch. Are the relay and switch the same thing? BTW My stock fogs have been replaced with aftermarket, and wired straight from the battery, they are on a totally different circuit. Ideas? Thanks.
CarolinaRumble is offline
Old 10-20-2010, 07:24 PM
Bubba 95SN
Replace the mutifunction switch.
Bubba 95SN is offline
Old 10-21-2010, 12:58 AM
CarolinaRumble
Default ok witch switch
Do you mean the hi/lo switch on the steering column, or the pull switch on the dash that turns the lights off and on?
Old 10-21-2010, 03:48 PM
Bubba 95SN
On the column is multifunction switch.
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Drastang
09-29-2015 03:31 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: Where is the headlight relay located
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
