94 gt headlight (HID) problem,
Old 11-01-2010, 04:25 PM
christopher_94_gt
christopher_94_gt's Avatar
Default 94 gt headlight (HID) problem,
ok i got a set of HID's (*9007) and they plug in and all but do nothing.....
so i thought it was a fuse but couldnt find one blown so i put old ones back in and they work>> ANYONE that can help plz give me some advice?!
thanks in advance!
christopher_94_gt is offline
Old 11-02-2010, 04:30 AM
christopher_94_gt
any help?
Old 11-02-2010, 10:16 AM
AdderMk2
Banned
AdderMk2's Avatar
you havent given us any information yet....
have you tried troubleshooting the problem yourself? did you verify that the wires in the plug are the correct polarity? The cheap HID makers will ofter put the wires in the wrong spot in their harnesses. I had to fix mine when I got them because the high beams and low beams were wired incorrectly. I had to drive around with my high beams activated, to use the low beams function.... stupid cheap asian labor....
AdderMk2 is offline
Old 11-02-2010, 03:11 PM
christopher_94_gt
ok, i have went through and looked at each wire and made sure it was all connected, also the (9007) bulb is only low beam *at least it looks to be... brights dont work or anything....
i dont know how else to explain "they do nothing"
the kit is as follows : two ballast, two 9007 6k bulbs and the wires that go to original plug and ballast...
Old 11-02-2010, 04:30 PM
AdderMk2
Banned
AdderMk2's Avatar
i didnt say that the wires arent in there... im saying you need to check the POLARITY of the wires to make sure you are putting + to + and - to -
and 9007 should be hi and lo... you bought a ****ty cheap kit
AdderMk2 is offline
Old 11-02-2010, 06:06 PM
christopher_94_gt
yessir i did, and i realize what u said, i was just stating what all i did.
StalkerGT
11-28-2015 03:09 PM
kawiguy827
09-22-2015 10:52 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: 94 gt headlight (HID) problem,
