do clutches burn up after one day of use?(just bought the car and took 4 hours b4 i had problems.)
yes... if it's not adjusted right it sure can. or if you shatter it from a hard launch
Originally Posted by darkemp
im using the stock quadrant.
thats is most likely your initial problem, and what caused you to smoke the clutch.
a manual trans will run on zero fluid. the gears would wear out from it, but it's not like a auto that uses a fluid link. worst case scenario in a manual that the clutch still partially engages.... your stuck in one gear due to sunchros being shot... but that one gear will work fine
your only partially engaging... and because your partially engaged... you have smoked the clutch and burned up the PP too
