Oil Pressure Question
Hey guys,
I was watching my oil pressure gauge on the cruise I took today and noticed that when I am idle, I have only around 7psi on my gauge. As I drive i goes up a little bit. It seems like I am getting about 10 psi for every 1000 rpm or 1 psi for every 100 rpm. Is this normal, or should I be concerned? At idle, even the factory gauge is showing nothing.
Any suggestions?
Thanks for the help in advanced.
Any suggestions?
Thanks for the help guys!!
Well, it is a mechanical gauge and it has the stock oil pump. That low of pressure just makes me nervous. Would you all recommend upgrading to a high volume pump? If so, what brand would you go with?
