Battery Dying
Battery Dying
I have replaced the battery in my 91 fox with a new one. Overnight it drains down. I can't seem to locate the source of the current pull. No lights on- interior or exterior. Put a meter on the positive cable on the battery with nothing on- pulls 4-4.5 amps. Ground is good on the negative cable. The alternator is putting out around 13- 13.5 amps when car is running. This is with no radio and the doors closed. Does anyone have any idea what may be pulling the battery down. The car is a convertible, only has 2 interior lights. No check engine lights on either. Kinda at a "DEAD" end on this one. Any help or advice is appreciated as to where to start troubleshooting. Thanks.
4 amps is a relatively large draw for whats supposed to be an idle system. i'd start looking into larger electronic components, like blower motor, or a large sound system(if you have one).. stuff like that.
Car stays parked in the basement of my house-50 to 60 degrees. I don't have any crazy stereo equipment. I'm leaning towards the ignition system being the culprit. Been a busy weekend so haven't had a chance to tear into it. I appreciate the feedback so far. Thanks!
Took the old battery to advance auto, they checked it. I was told it had a bad cell in it because it wouldn't charge completely or hold a charge. Now that I think of it, the battery may not have been bad, good thing Wal-Mart prorated it. New one cost less than 20 bucks. Still haven't looked into it yet. Hopefully this week things will be less crazy. I appreciate all the feed back. When I do find the problem I will post it in case anyone else has this type of situation occur. Everything in the car is totally stock. That is why I am a little confused. This happened all of a sudden. The car is not subject to drastic temperature change or anything like that.
