Big Problem help please
hi guys i just had my aode transmission rebuilt and out of nowhere. when i accelerate from a stop and i slow down then re accelerate my transmission makes a whine noise and rpms jump and the car doesnt accelerate. so whats going wrong. thanks
Hey man, i had a lot of trouble with aod's, enough of trouble that i switched my car to five speed, I had someone build me a racing aod with shift kit redline clutches etc that was built to handle 480 rwhp, well long story short it failed about 9 times, I would always loose 3rd and than overdrive, btw my car isnt even close to 480 hp i was building it up for future mods, I replaced everything shift cable, tv cable, had the tv cable adjusted twice by an outside trans specialty shop it just never was going to work for me, so basically my advice is if you cant get it right, take that junkbox aod out put in a c4 or go five speed, the amount of aggrivation and time your going to spend trying to get that right just isnt worth it in my opinion, my aods a boat anchor now sitting in my garage.
Refreshing my memory sounds like the case is cracked, that happend to me the 3rd time it was rebuilt the case was cracked i was losing pressure agaisnt the clutch plates when i slowed down and than stepped back on it, you probably wont be able to see the crack cause i couldnt either it was internal but that would be my guess and if its got 300 miles bring it back and tell them something along those lines atleast thats how i would handle it, AODOCRAP haha
