Engine Prices What would you pay for this setup?
302 bore to 306
Eagle rods/new pistons un-sure make
Power plus upper and lower
comp cams roller rockers 1.6's
24lbs injectors
75mm trottle body and spacer etc
C&L Mass air 76 MM I belive
Rouch Heads
Extreme energy comp cams
stud gurtle for bottom
hi flow/bored oil pump
Arp bolts compete for engine
Complete from oil pan to upper. Looking to see anyones thoughts on what you would pay for the engine setup above?
I know the guy that built it as well as my buddy had it in his car 89 coupe, best times was 12.5 on engine and 11.60 with 100 shot of spray.
Anyones thoughts on what this is worth if I were to buy all new and assemble myself or have someone do the work. I have got different prices on how much $ as far as parts are in this engine. Please note I from canada so what would be your thoughts on how much in parts this engine is worth.
Thanks Eric.
24lbs injectors
Rouch Heads
Thanks Eric.
RE: Engine Prices What would you pay for this setup?
how many miles are on all of it. its got a pretty penny in it, but the rousch heads arent that great, and ive never heard of boring the oil pump, so maybe you mean high volume or high pressure oil pump. anyways, if its a low mileage motor, and the guy didnt abuse it(besides the spray) alot, then i would say around $2000 max.
The engine has Nothing on it for km, it had maybe afew thousand but then was completey looked over and freshed before it went in my car alone.
Thanks for your thought, I think more then $2000 tho thats for sure eagle rods/Power plus upper and lower comp cams roller rockers 1.6's
24lbs injectors 75mm trottle body and spacer etc C&L Mass air 76 MM I belive
Rouch Heads Extreme energy comp cams
All parts are brand new lol if i were to price them out it is surely more then $2000 in parts may not be worth that too many once there used but keep in mind I know the guy who built the engine as well as the guy who owned it is one of my good friends. I'll get other specs but theres at least $5000 in parts in this engine everything was done from top to bottom.
The heads/rods would be over $2000 new, rockers $400, not the best thats for sure by all means but should be quite the difference from stock.
I'll get the full list of specs, there may have been other work done to the engine as I know he had about $5500-6000 into the engine. he went with a 347 now tho and is getting abit quicker then the times he got with this engine.
I hope I'm happy with it i'll see how things work out.
YoungStangsMan
09-05-2015 07:01 PM
