Fuel pump problem?
Old 12-30-2010, 11:49 PM
chilywily72
chilywily72's Avatar
Default Fuel pump problem?
At first i thought it was normal but my fuel pump whines pretty good sitting idling its pretty loud and running down the road you can still hear it pretty well and it never shuts off is this normal or do i have a bad relay or something?
chilywily72 is offline
Old 12-31-2010, 01:48 AM
enix187
enix187's Avatar
you're good, you'll know when its broken
enix187 is offline
Old 12-31-2010, 09:01 AM
Mustang5090
Mustang5090's Avatar
I had the same problem, thought my fuel pump was on its way out so i gotta new one with a aftermarket regulator, turns out when i went to set the new regulator my car was running 100 psi of fuel pressure at the rail as it turns out my return line was clogged which caused my pump to wear out from constantly pushing against 100 lbs of fuel pressure, im sure your have the same problem you might wanna look into that as youll start flooding your injectors run super rich etc etc
Mustang5090 is offline
Old 12-31-2010, 07:17 PM
Bubba 95SN
Bubba 95SN's Avatar
Keeps running after you turn the key off?
Bubba 95SN is offline
Old 01-02-2011, 12:52 AM
Dj_Seph
Dj_Seph's Avatar
I car hear mine whining pretty well too. But then again, I have a trap door cut into my trunk for easy fuel pump changes. lmao Probably should insulate the door or something.
Dj_Seph is offline
Old 01-02-2011, 06:34 AM
91Vert
91Vert's Avatar
Mine is loud too. I hope it doesn't go out, I really don't feel like putting in a new one.
91Vert is offline
Old 01-04-2011, 12:33 AM
ponyponer
ponyponer's Avatar
mine has been whining for the last 2 years. actually over 2. ever since september of 2008 i think it was. it's been about 17k miles now, and it's still going. the pump has almost 100k miles on it.
ponyponer is offline
Old 01-04-2011, 12:48 AM
tohoopty
tohoopty's Avatar
mine used to be really loud.then i changed the fuel filter and i almost couldnt hear it run.about a month later the pump died lol
tohoopty is offline
Old 01-04-2011, 05:15 AM
91Vert
91Vert's Avatar
Damn, how bad was that thing clogged?!
91Vert is offline
Old 01-04-2011, 04:17 PM
tohoopty
tohoopty's Avatar
i could barely blow through it
tohoopty is offline
Quick Reply: Fuel pump problem?
