bigger front brakes
bigger front brakes
spring is around the corner and one of my many upgrades is going to be my front brakes . I bought a complete set of front spindles from a 2004 stang that i plan on using on my 1984 stang cv.My question is will i need to buy anything else to do this like,camber-caster plates? I am also planing on changing springs to a 1" drop. Will i be able to get a correct alingment? Will there be any other thing to concider?
i highly recommend get caster camber plates to get a true good alignment. Also, i'd recommend a bump steer kit and replacing your tie rod ends as well if they haven't been replaced recently. and if the spindles are used, it wouldn't hurt to replace the ball joints as well. i think that should be good! have fun!
maestro1024
09-21-2015 02:40 PM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
