New Rear suspension is really tight????
Old 03-25-2011, 12:57 AM
1990boostang
1990boostang's Avatar
Default New Rear suspension is really tight????
Im finishing up my winter project and just got it off the jack stands for the first time this year... But it seems to be really stiff in the rear. I put late model resto control arms with comp. engineering drag shocks and 4 cyl. spring in the back. I can sit on the back of the car and it barely moves and im 6' 6 and 235lbs. Any ideas..?
1990boostang is offline
Old 03-25-2011, 02:18 AM
AdderMk2
Banned
AdderMk2's Avatar
i hope you didnt torque everything down while it was up in the air.
AdderMk2 is offline
Old 03-25-2011, 05:25 AM
holyshift
holyshift's Avatar
What he said, gotta at least put a jack on the rearend and jack it up to the ride height,then crank everything down.
holyshift is offline
Old 03-25-2011, 06:45 AM
4rdnut
4rdnut's Avatar
I don't know if 4 cylinder springs lower the rear, i would check the pinion snubber to see if its sitting on the top of the center section of rear axle, you should have at least 1 inch of clearance.
4rdnut is offline
Old 03-25-2011, 01:04 PM
1990boostang
I did have jack under the rear end when snugged up everything... There is about 1.5 to 2" between the diff. housing and the rubber bump stop. Im gonna go out and loosen everything back up and try it again and see what happens.
Old 03-25-2011, 09:04 PM
holyshift
holyshift's Avatar
The comp engineering shocks....what were they....50/50,70/30,etc??
Old 03-25-2011, 09:22 PM
tohoopty
tohoopty's Avatar
my bet is the shocks are stiff.i got kybs on mine and i can barely budge the car when i push on it
tohoopty is offline
Old 03-26-2011, 03:45 PM
holyshift
holyshift's Avatar
Thats what Iam wondering if he got the stiffer shock....youll be alright,unless it doesnt hook up....Thats why I like my Strange 10 ways....I can adjust them to whatever.
Old 03-27-2011, 01:36 AM
1990boostang
I have them set at 50/50... They are 3-way adjustable...
Old 03-27-2011, 11:45 AM
holyshift
holyshift's Avatar
Explains a little bit.I wouldnt worry about it.
mtgldr
02-03-2024 09:00 PM
musnicki
09-23-2015 07:11 AM
GimpyHSHS
09-18-2015 12:27 PM
09-08-2015 11:50 AM
RWHEELS
09-05-2015 03:42 PM
Quick Reply: New Rear suspension is really tight????
