you mean the seal in the input shaft retainer?? I've never had one of those leak, often it leaks from the bearing with the o-ring in it for the cluster gear that is below the retainer, inspect both if that is what you are after.
+1. Never heard of that seal leaking. But if you're gonna take it apart then don't forget to check and see if the rear main seal is starting to weap or leak at all.
