battery
Old 01-28-2011, 10:07 PM
93 stallion
93 stallion's Avatar
Default battery
What to put my battery in the truck. Do I have to run the ground cable where its connected now or can I just bolted some where on the back body n what size cable should I use
93 stallion is offline
Old 01-28-2011, 11:23 PM
enix187
enix187's Avatar
connect it in the trunk, I would run an engine ground from where the current one is too, and it should remain the same size or bigger if possible
enix187 is offline
Old 01-29-2011, 12:11 AM
LesteR723
LesteR723's Avatar
here you go!:
https://mustangforums.com/forum/5-0l...made-easy.html
you're welcome... in advance
LesteR723 is offline
Old 01-29-2011, 08:43 AM
AdderMk2
Banned
AdderMk2's Avatar
When I did my battery relocation, I put a ground wire down through the trunk pan, and onto a thicker part of the unibody, and also ran a smaller gauge wire up to the front and connected it directly to the side of the block.
AdderMk2 is offline
Old 01-29-2011, 10:49 PM
holyshift
holyshift's Avatar
Always was told to run a ground back to the block or else could cause electrical gremlins.
holyshift is offline
Old 01-29-2011, 11:26 PM
Bubba 95SN
Bubba 95SN's Avatar
Make sure you have plenty of ventilation... fumes may make the Trunk Monkey ill.
Bubba 95SN is offline
Old 02-03-2011, 10:30 AM
.boB
.boB's Avatar
You can ground it directly to the chassis, and not run an additional wire to the front. That chassis will act like a huge ground wire.
An additional wire or braided ground strap from the front of the chassis to the block is a good idea, though. Sometimes the motor mounts will prevent a good ground.
.boB is offline
Old 02-03-2011, 11:03 AM
AdderMk2
Banned
AdderMk2's Avatar
I thought the same thing too until I started reviewing how many different welds, joints, and attachements there are from the back of the car, to the front. The resistance from one end of the chassis, to the other, is significantly greater than it would be if you ran a ground wire up to the block. Which is why you should add the additional wire to the front.
It all a matter of electrical principles... Its just smart to do it!
AdderMk2 is offline
BOB ROME
07-26-2023 01:54 PM
4cylinderplus2
10-09-2020 07:45 PM
logan409
09-26-2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Art161
09-09-2015 10:33 AM
Quick Reply: battery
