Turn signal flasher location for 90 LX
Old 02-02-2011, 03:50 PM
Quickbird144
Quickbird144's Avatar
Thanks for the diagram. It's actually one that was sent to me by dreamer1uk. But did go over it and still nothing. Tried 3 different working multiswitches and nothing. Tried a new hazard switch and nothing. I'm a bit lost now =/
But. I did find a inertia switch mounted to the rear of my car, in the hatch area, where the tail lights mount. What is this for?
Quickbird144 is offline
Old 02-02-2011, 04:06 PM
tohoopty
tohoopty's Avatar
that inertia switch is for the fuel pump
tohoopty is offline
Old 02-02-2011, 06:23 PM
Quickbird144
Yeah just read up on that. Don't want to mess with that! I wonder what the deal is here.
Old 02-02-2011, 06:38 PM
Quickbird144
Hey I found this cluster wiring diagram. Would it be smart to get a test light and see if it's putting out anything to the indicators?
http://www.stangnet.com/tech/cluster87-93.pdf
Old 02-02-2011, 07:55 PM
dreamer1uk
dreamer1uk's Avatar
Start with the basics. Do you have power going to the turn signal switch? If you do, how did you check and with what methods?
dreamer1uk is offline
Old 02-02-2011, 08:32 PM
Quickbird144
Actually I have not. How do I go about doing so?
Old 02-02-2011, 09:54 PM
dreamer1uk
dreamer1uk's Avatar
Another PM sent
Old 02-04-2011, 09:06 PM
enix187
enix187's Avatar
even though if you said your flashers work so its getting power, its when the relay is powered that would be useful, if the turns work when you use the flashers but not the turn signals that would point more towards your actual turn signal switch being bad.
enix187 is offline
Old 02-04-2011, 09:30 PM
dreamer1uk
dreamer1uk's Avatar
I didnt think the fox bodies had relays? Even the wiring diagrams i have do not point to any relays. There are flashers for the hazards and turn signals but they are completely different from relays
Old 02-06-2011, 12:51 PM
holyshift
holyshift's Avatar
Check your ignition switch in your steering column. Pry sounds retard but I had the same issue for awhile and i found my ignition switch was loose,and that was the problem. I dunno if the turn signals get power from there or what but....check it out.
holyshift is offline
jwog666
12-27-2021 08:09 PM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
09-27-2015 03:16 PM
logan409
09-26-2015 07:43 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: Turn signal flasher location for 90 LX
