WHATS A GOOD CAM?
what would good specs, lift/duration, be for a cam to be put into a 92 LX. only mods are BBK headers, and Borla cat-back, and underdrive pulleys. It is a 5 speed and is for street use. Id like a good sound, and the most performance by dropping in the cam. I dont want to get into any extra engine work. not yet at least.
RE: WHATS A GOOD CAM?
Honestly man, don't waste your time on a cam this early on. You don't have nearly enough parts on that engine to have any need for an aftermarket cam. Look into a bunch of worthwhile mods before doing the cam because the stock 5.0L cams are good for something like 500hp-ish and some quick 1/4 miles.
One of the guys in my club had a '92 LX until this summer that was blown with a Novi 1000 and modified more than most of the Stang I've seen around. The car ran an 11.76 in the 1/4 and he still used the stock cam. |
ORIGINAL: SilentNoise Honestly man, don't waste your time on a cam this early on. You don't have nearly enough parts on that engine to have any need for an aftermarket cam. Look into a bunch of worthwhile mods before doing the cam because the stock 5.0L cams are good for something like 500hp-ish and some quick 1/4 miles. One of the guys in my club had a '92 LX until this summer that was blown with a Novi 1000 and modified more than most of the Stang I've seen around. The car ran an 11.76 in the 1/4 and he still used the stock cam. |
thanks for the advice, i already have pipes and headers, what can i do for a more radical sound?
he's right... you dont have the mods that would match right for even a street cam. with the mods that I have listed in my sig., which are on my car is a good combo for a "street cam", nothing more. my duration is 218 for intake and 224 for exaust. my lobe lift is .3200. lobe seperation is 112.0. my cam is a comp cam 270HR extreme energy... fits small block 302 or 351W. ford part no. is #35-324-8 if interested, but get the right mods first.
ORIGINAL: ballzoutstang875.0 he's right... you dont have the mods that would match right for even a street cam. with the mods that I have listed in my sig., which are on my car is a good combo for a "street cam", nothing more. my duration is 218 for intake and 224 for exaust. my lobe lift is .3200. lobe seperation is 112.0. my cam is a comp cam 270HR extreme energy... fits small block 302 or 351W. ford part no. is #35-324-8 if interested, but get the right mods first. ORIGINAL: kartrcr7789 thanks for the advice, i already have pipes and headers, what can i do for a more radical sound? - Is it legal for you to run without cats? - Do you have aftermarket mufflers? - How about an X or H-pipe? (changes the exhaust note a bit... nothing really radical though) |
mine does fine performance wise with my mods and cam... how would that not work for him? you dont NEED heads+manifold for a very mild street cam, i get comments about my setup all the time.
unfortunately, i live in the worst state ever when it comes to cars, massachusetts, well other than california i guess. anyone, its not legal to run it without cats, i have BBK headers and Borla cat-back
ORIGINAL: ballzoutstang875.0 mine does fine performance wise with my mods and cam... how would that not work for him? you dont NEED heads+manifold for a very mild street cam, i get comments about my setup all the time. When you're that early into a project, it's pretty easy to spend a few hundred bucks on other things that your engine can benefit from which will get you better results. |
yep this guys correct^^^^^^
