Eletric fan install
Eletric fan install
I have a mark VII fan sitting in the basement and i wanted to install it on my car i was just wanting to know how everybody else on the forum has installed theres. Do you have to install it with the thermo or should i just run it all the time when the car is running
RE: Eletric fan install
Keep the Clutch Fan!!! there WAAYYYYYYYYYY better then those POS electric fans, i have friends that run them and dont have anything but probs, there always running way hotter than me! i would stick with the stock cluctch fan, it isnt drawing that much power from ur motor,
they had the black magic, and some had some from the junk yard off other cars, im not sure i was gona put a electric on to but to i notice that and didnt wana run that hot, but it might be just there cars, every ones dif, i like the clucth dont have to worry about a sensor going bad and not turning on,
i have one off of some ol japanese thing from a junkyard, it stays nice and cool. all i did was run a wire from it to the fusebox to the fuze the cd player goes to, so when u turn ur key on..fan is on.
do it right and spend the 80 dollars on a flexalite VSC. thats how i installed many of LS1/LT1 fans. they are a dual fan setup and they fit right at home on a mustnag rad. use the VSC to turn them on anything you wish or have the probe sense when to turn them on. this is the best and safest way to do it
use a heat probe to turn it on and off. if you run it all the time, you will kill the fan. in winter my fan never even comes on. right now its 90* out and the fan still doesnt run all the time. i have my probe set for 185* with a 180* stat and it works great for me
