302 RUNNING LEAN
about the caps lock i was at work and thats all we use there,i was told by a few ppl that it smells like im running lean and am not getting any codes on the dash would i have to hook something up to get the codes? the wires/plugs/cap/rotors look good the spark plugs are gapped at .44 how can i check my timing
thanks
thanks
my fuel pressure is at 36 with the car on a cold start what should it be at?and should i check it with the car on or off also warm or cold im new to this as you can tell
Just follow the steps of the following DIY KOEO/KOER/Cylinders Balance Self Tests Procedure and LUK.
So there's not actually anything wrong with it then? It runs fine, no codes etc? But...someone told you it "smells" lean? You need to go to that person, and slap their *****.
And what car is this on? The 05 you list? It doesn't have a cap or rotor.
Galactic
04-29-2019 02:56 PM
