Rod Bearing Question
Old 03-06-2011, 07:12 PM
87Stallion
87Stallion's Avatar
Yeah Clevite said dont touch them at all. So my options are to run 1 half of a .001 oversized bearing and 1 half of standard bearing or try to get my machinist to polish off a .0005 which will be tough.
87Stallion is offline
Old 03-07-2011, 06:30 AM
uedlose
uedlose's Avatar
Did you ask Clevite about running a half shell mix?
uedlose is offline
Old 03-07-2011, 02:03 PM
87Stallion
87Stallion's Avatar
No I didnt but I plan on it.
Old 03-07-2011, 02:46 PM
87Stallion
87Stallion's Avatar
Just talked to Clevite. They said it was ok to run the bearings this way. Guy said its a common practice with aftermarket cranks
Old 03-07-2011, 03:15 PM
67mustang302
67mustang302's Avatar
Then you might want to stick the larger shell(the one with more clearance) on the rod side and not the cap side. You're going to have half of the crankpin with .001 radial clearance and the other half with .0015 radial clearance. Since the rod side is the one that's more heavily loaded during combustion, putting the large clearance shell on that side gives it a bit more room. Too loose will live, too tight won't, as the saying goes.
67mustang302 is offline
Old 03-07-2011, 03:55 PM
87Stallion
87Stallion's Avatar
Makes sense. Thats what Ill do. Thanks for your help
guitarman376
10-11-2015 01:47 AM
rksnow1
09-14-2015 08:46 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Rod Bearing Question
