Hesistation at 4000rpms while hot
I have a 93 GT idles perfect and runs perfect until about an hour of driving it. at that point everything is still good until i get up around 4k rpms the i get some hesitation and power lose. i had the codes ran and nothing, no check engine light, changed out my cap and rotor, TFI module and im running 91. My fuel pump is making a **** load of noise though, sounds like i have a blender running in the back. my new pump will be here monday, is that most likely the problem now?
RE: Hesistation at 4000rpms while hot
ORIGINAL: 86HOGT
It should be fine, since you have a regulator already, it's just not adjustable.
ORINGINAL: mustang30540
does it run fine when its at full throttle? if so it may be the 02's thats what mine used to do before i replaced them.
well, since ur gettin the new pump, just try that for a while first. if it keeps acting up with the new pump, THEN consider some o2's or something else. always try to test out one part at a time when applicable :P
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
