running rough
Old 04-01-2011, 07:03 PM
93 stallion
93 stallion's Avatar
Default running rough
A mechanic installed several things in my car. After that I been having a lot of problems with it not running like it was before. He changed out the tb, intake, distributor, n coil. They set the timing already but the car still running rough, it idles good but when it runs, its like pulls. Does any body know what could be wrong or can it be the tb
93 stallion is offline
Old 04-01-2011, 10:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
so which is it?? a mechanic installed a bunch of parts and now it runs rough?? but after that you mention it still runs rough like it did before?? DO you mean a mech installed a bunch of parts in an attempt to correct a rough run issue and it didn't correct the issue??? if such is the case then why are parts being thrown at it , instead of the prob being troubleshot?? who and why were theses parts recommended??? Cause a friggin' tb...doesn't take rocket science to figure that won't fix a rough run...as well as an intake....or did you do the cardnial sin of adding a mod to a engine that was not in perfect running order??? PLEASE FILL IN ALL THE HOLES IN YOUR STORY, cause there are too many!!! explain the issue at hand better!!!
mjr46 is offline
Old 04-01-2011, 10:46 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
i wish people would learn how to speak clear, proper english...
after what i saw out on the road today coming back from Ohio (through the snow... and one of my traps came loose midway through PA...) i think ive lost any and all faith in humanity...
thank god i was driving a friggin Peterbilt not the Mercury lets just put it that way...
sn95_331_GT_ yellow is offline
Old 04-02-2011, 12:35 AM
93 stallion
Sorry im not an expert, any ways the car was running fine but I wanted to upgrade the intake and tb. When he pulled out the distributor he saw oil in it,So I bought a msd distributor and
the coil. Also all the parts are used.
Old 04-02-2011, 09:15 AM
nightmare90gt
nightmare90gt's Avatar
never buy a used coil or dizzy i would start at the coil and go from there many people on this forum have had bad luck with msd coils
nightmare90gt is offline
Old 04-02-2011, 09:20 AM
mjr46
mjr46's Avatar
1 of three things, either the mechanic fubared the intake install and there is a vaccum leak, or the parts you bought are bad
mjr46 is offline
Old 04-02-2011, 09:52 AM
stdyhand
stdyhand's Avatar
I think mjr is on top of it. I wouldn't have bought used parts though. Usually it isn't much more for new parts and they usually have a warranty, sometimes a lifetime which I look for.
This is also a good example of why I don't trust just any mechanic and why I do as much work as I can myself. It doesn't mean it was the mechanic, but the good part about doing it yourself, if you can, is you know it was done right.
stdyhand is offline
Old 04-02-2011, 09:58 AM
mjr46
mjr46's Avatar
mechanic or not, even if one does it his/herself it all lies in ones tech ability
mjr46 is offline
Old 04-02-2011, 10:14 AM
stdyhand
stdyhand's Avatar
True. Assuming he/she knows what their doing then you know it's done right.
It's been my experience that most "mechanics" do not know what their doing. That's why I ask so many questions and do it myself. I don't mind the work, just got to gain as much knowledge as I can ahead of time.
stdyhand is offline
Old 04-02-2011, 12:22 PM
93 stallion
Ok, I will buy a new coil and let you'll know how it works after that.
Thanks
Quick Reply: running rough
