Tach and other gauges dont work as well as alternator
I have an 88 GT with AOD. Last weekend I pulled the dash to replace the heater core, in doing so I forgot to reconnect a vacume hose for the heater vent system and also my gauges dont work. My gas gauge is the only one that works apparently, which I dont know how well it works but it moves. My speedometer works which I know is cable driven. My alternator gauge is bottomed out but it just so happens that my alternator doesnt work now either. I've done some searching with no luck.
I've checked the #18 fuse which is still good, I've removed the gauge cluster and re-installed it with no luck still. What would be a good way to troubleshoot this?
Thats exactly your issue then too. If one is upplugged then you are probably not charging either. The 12v signal to the alternator goes thru the cluster so if its not connected you will not get the excitation voltage that the regulator puts out.
got it all put back together everything works good and charging.... makes me rethink replacing the alt but I had them test it before I returned the core..... it failed the test so atleast I have it fixed now
HIS S-197
08-10-2015 05:47 PM
